out of the box, the higher end cards with the 10+2 design use more power. they are clocked higher so this is normal but performance is almost the same. little fps to gain at stock clocks to justify the more expensive model. however, they also have dual bios on them if you may wish to play with custom bios settings. otherwise, stick to the sc card as it is a great performer for the money
