So I've just purchased an EVGA RTX 2060 Super off of Ebay, used, but should be functioning. Everything is working as expected apart from Fan 2 which, even when the GPU's temps reach 75C whilst running Cyberpunk 2077, it doesn't spin. There has only been one occasion in which it did, but that was when loading up my save game (literally haven't seen it spin any time before this, kind of bizarre)
So it's clearly able to function, but it just.. doesn't. Wondering now if I should return the product to the seller, or if there are any solutions out there that may help, that don't including taking the whole thing apart, as by that point I might as well return the item.
Upgrading from a EVGA GTX 970. Motherboard, CPU & RAM are brand new, and everything in my build appears to be compatible. I'm using a 6x2 pin connection however, but was led to believe this wouldn't cause any issues. Have tried to manually have them running at 100%, first fan works perfectly, second doesn't start. Have tried EVGA Precision X1, MSI Afterburner, Furmark, etc. Essentially, I've tried almost all solutions that appear when Googling an issue like this, but no luck. Any suggestions?
Specs:
OS: Windows 10 Pro 64-bit
CPU: Ryzen 5 3600
Motherboard: MSI B450 TOMAHAWK MAX
RAM: Corsair Vengeance LPX 16GB 3000MHz
PSU: Raidmax RX 1000AE (1000 watts)
SSD: Samsung SSD 860 QVO 1TB
Specs:
CPU: Ryzen 5 3600
