Review EVGA RTX 2080 Super XC Hybrid Review: Cool Running, but Worth It?
The TL;DR:
No, no it is not.
I would've thought a liquid cooled gpu like that would've performed a fair deal better than an air cooled model like the ROG Strix...
Did they take a FE 2080 Super PCB and slap the AIO on it? The FE only has a 280w power limit, and Asus Strix has a 313w limit on the OC model.
It would be nice to see comparisons of the different hybrid cooled cards out there (EVGA's Hybrid, Gigabyte's Waterforce, Inno3D iChill, etc.). I use these for my iTX build, and apparently there are many differences in noise and cooling performance. And while there are some reviews online, it's really hard to come across comparisons.
Some of us like to use the high end cards for Folding. Most card reviewers don't give a single sentence in that area as to how various cards do in that arena. So, we have to search that info out in other areas. "It would be nice" to see a reference in video card reviews - even if it's only a sentence or two.
The EVGA RTX 2080 Super XC Hybrid performed well, averaging over 100 fps at 1440p ultra and 60 fps at 4K ultra. The hybrid cooling kept the card much cooler than other cards, but the pump has a soft hum. Priced at $789.99, it's one of the most expensive 2080 Super cards available, but only similar Hybrid setups can cool as well.
EVGA RTX 2080 Super XC Hybrid Review: Cool Running, but Worth It? : Read more
Why didn't you guys review the FTW3 version of this card which has a higher boost of 1845Mhz? I paid $769 for it too on Newegg back in September. It's actually going for around the same price right now.
Everything in your review is spot on. It rarely eclipses 53 degrees even when it's working it's hardest. It can overclock it's butt off but I put it back to stock as it's really not necessary since I'm gaming on the Dell S3220DGF monitor. The pump wine does sort of bother me but I've gotten used to it. I wish it could be controlled.
The one real issue with this is card is that the radiator fan can't be software controlled with Precision X1 or Afterburner. You can only independently control the GPU fan. All software reports them running at the same speeds which certainly isn't true.
Are you aware of any objective way to test that? F@H doesn't have a benchmark tool (that I'm aware of) and of course they can't just sit there hoping they get a WU, wait for 2 hours, repeat to average results, and just cross their fingers that one WU will be the exact same as another from the same day let alone of months.
They can perhaps derive it from the other tests done but that specific one would have to be speculation.
