"1) I was also one of the persons who were confused, but because someone gets confused doesn't mean that the list is wrong!!"
True. However, does it necessarily mean the list is by any means complete yet, and thus definitely "right"? To the point some odd and conflicting placements between tiers 1 and 2, have begun to be explained with any degree of satisfaction? If some placements remain as they are presently, I'd wish to know why. Especially given the discrepancies between some units' ultimate scoring and their list placement, (including the site's own reviews, regardless of author), noticed by some of the site's faithful readers.
"2)What do you mean by that? That according to your opinion, your EVGA P2 belongs to Tier1? I also own an EVGA G2 750 & 850. Surely i would like to see them as a Tier1 units . So what? Do you or i, have higher expertise than Jonny on the PSU field? !!!!"
Speaking for myself, I'd say no. Allow me to put it another way: If, after the considerable research I did, taking the reviews from JohnnyGuru and other sites into consideration, I thought Seasonic's 1kw platinum equivalent (or the others for that matter) held a considerable, tangible, qualitative advantage over the Evga 1kw P2, I would've gotten it or something else over the Evga P2. And just fwiw, I'm not attached as a fan to this or any other particular company. I chose a Nitro r9 390 for a gpu, where most would've surely chosen an nvidia instead. Why? Well, aside from the fact if we find ourselves subject to a total intel/nvidia monopoly in the near future, we'll have no one but ourselves to blame, it's actually an excellent card for the money, a great wqhd card as it turns out, with overall excellent build quality. Sry to get off track, just wanted to make that point.
Anyhow... The PSU list is a work in progress, which is prone to some changes and editing. According to Jonny's own post on that site's forum, on p5 of that thread he states: "Yeah, I plan to consolidate a bit. Like merge 1 and 2, for example."
"3) Jeremy & Jonny are both reviewers and used to work for the same site, but that doesn't make them identical twins!!, who are thinking exactly the same!! Apparently, according to his list, Jonny thinks as a Tier1 only OEMS like Delta, Seasonic and Flextronics, and the other OEMS are one step down. Lots of people probably will get confused, but the fact is that very few people have Jonny's expertise in the PSU field."
I agree, I'm curious to see what the list looks like when done.
