Question Evolv Shift 2 panel RGB not working ?
boyanhristow
16
Hello,
I've recent built into the case and the RGB in the top panel is not working (pic of how it should look like below).
I have only connected the SATA cable since my motherboard does not have RGB connections. However as far as I remember SATA should be enough to power a little light and 2 buttons controlling color and mode. I have changed the PSU SATA cables and made sure every single one was working properly so this is not a PSU issue.
My questions is is it worth changing the motherboard for one with RGB connectors if this will solve the problem OR is the case SATA connector faulty?
Any advise will be appreciated.
