Exhaust/Intake fan are having multiple problems:
Michael Hillyer
45
I have an intake fan and a exhaust fan, they've both worked forever now since I've had the computer. They're both connected to case switches which these switches just turns them off/on. Anyways, to make them both work at the same time these switches need to be on HIGH settings, they have a low settings then they have a off setting.
Now, this hasn't been a problem until recently. Now when I boot the PC either fan turns on, but if I go to the switches on top and turn one out of two off/on, One fan will turn off, the other will stay on, I do this for the other switch, vise versa happens. But if I turn both switches to HIGH (which this used to make both fans turn/stay on together) nothing happens, no LED, nothing. Recently, I've been getting lucky though, I've unplugged/replugged the fans in and they'd work, maybe for a few days then I'd have to do this after a few days as when the PC would turn on after 3,4 days of me doing this, they'd stop turning on with the PC. So, recently, this hasn't been working rather I plug them in, or unplug them and try they don't turn on. Sometimes I get lucky and they will but then they turn off (both fans) half an hour later. But, as stated above, I'm still able to mess with the top switches and get one out of 2 fans to turn on. So right now I'm sitting with all the fans on besides one which can either be the exhaust or intake, I have the exhaust on.
http://imgur.com/9c5KwTn
This photo explains it better.
I dont know your system specs, but are there any fan headers on your motherboard? You might be able to control the fans from the bios, depending on the feature set it has. This option should also eliminate the need for the external switchs, and the fans should come on when you power on the rest of the system.
It might also be time to just replace those fans, or the switches controlling them. Plenty of good fans to choose from, and you can find fan controler add-ons for around $15 to start.
OS: Windows 10 Home  –  CPU: AMD FX-8350 Eight-Core Processor (at 4000 MHz)  –  Memory usage: 3756/8174 MB (45%)  –  Graphics: nVidia GeForce GTX 750 Ti (1920x1080x32bit 60Hz)
And my Motherboard is a ga 78lmt usb3. And I'll have to check because yeah it's weird that my PC fans aren't starting up with the PC anymore, do you think taking them away from the switches and throwing them on the motherboard would be okay?
Yes. Moving the fans to the motherboard should theoretically be fine. If the fans are still having issues, they may be going bad. This is a cheap way to test them out too. If the fans are going bad, they dont cost a lot to replace. To test the fan switches would require swapping in other fans.
I should note: So long as the fans have the standard three pin connectors, they should connect to the motherboard just fine. If they have Molex connectors then this wont work.
It's possible the switch has a controller built into it as well that is going bad. You could even try replacing the switch. It's hard to troubleshoot a PC without being in the same room as it. But most times people just get a 3 pin fan and plug it directly onto motherboard fan headers. If your motherboard has 4 pin headers, get a PWM fan instead. It's quieter.
