Hello. I recently received a Toshiba P70-A-11Q notebook. The notebook allows the installation of a 2nd HDD. On the second slot i installed a Samsung 840 EVO 250GB SSD which i installed windows 8 on it.
After installing also the Samsung magician and activated Rapid, i made a benchmark. Here are the results.
Trying to find why the speeds are so low, my first thoughts went on AHCI. AHCI seems to be finally enabled. Second thought was that the interface the SSD is connected is not SATA-3. The answer is that the port is indeed SATA-3.
After running different software drying to identify if the SSD runs on Sata-2 or 3 i saw following (confusing) which i still am not sure in the end.
So it seems that the drive is on a SATA-3 but runs at SATA-2 speed ? If not what else could i check?
I know i should be expecting 100-150mb more.
Thank you in advance
