I've run into a bit of weirdness in win 2000/sp3/ie6 that I'm hoping someone might be able to help me with...
I was asked to remove the "Favorites" menu from the windows file explorer for security reasons (only certain employees are allowed web access). This would normally be simple enough, just go into the registry and turn off the "Shell Extensions" in Internet Explorer.
But, when I did that all the pre-set explorer views were lost and everything reverted back to "Large Icons". Now this person wants the views to default to "Detail". The button on folder properties to make "all windows like this window" only goes across top level directories without the shell extenstions turned on. I can get it to do what they want on a directory by directory basis by enabling the "Save Explorer Settings" and going into each directory in turn and setting the view state... except ths machine have something like 5 or 6 <i>thousand</i> directories in it. Could take weeks to do that and I'm pretty sure they will want it done before then...
So, I'm left with a some questions...
1) Is there a way to remove the "Favorites" menu from file explorer without disabling the IE shell extensions?
2) Failing #1 is there a way to default the file explorer's view to "Details" without the IE shell extensions running?
3) And if 1 and 2 aren't possible... is there utility that will mass-set the file explorer's view settings according to what I specify?
This is for a shared workstation on a small network but we are only concerned with local settings.
Any help with this would be appreciated...
--->It ain't better if it don't work<---
