Extend displayport over ethernet
ms228
66
Hi,
I would like my PC in a different room to my monitor and was wondering if it is possible to extend displayport technology at 2k (and g-sync) over Ethernet, or any other means? Looking online it seems to suggest the max distance displayport can reach at 2k is around 5m.
Thanks,
Mark
I had a feeling that may be the answer.
Running a ROG Swift at 2560 x 1440.
Can you think of any other way to run the PC and monitor in different rooms?
Cheers,
Mark
As the ROG Swift does not have a HDMI In connection, what would the best way to connect and still be able to use the g-sync technology? Could i use HDMI out of the PC then convert to Displayport?
Thanks,
Mark
