Extend my Wifi range
Gamerfluff
7
I live on a farm and would like to extend my Wifi to reach about 200 feet more so I can access it from all my buildings without buying more routers/lines. Could you recommend a decent, cheap range extender to use? Preferably to use on B, G, or N and under 100 dollars.
There are no good cheap range extenders in my opinion. You might get decent range with an outdoor access point. Mount it to the side of the main building pointed at the out buildings. Tie the outdoor access point to your main router with ethernet cable. If your out buildings are not clustered, then you would need a couple outdoor access points to cover a wide arc.
