Extending wireless range using two e4200 routers
wwratekin
5
Hi guys,
So I am trying to extend the range of my WiFi and have tried several things to do the trick but nothing has really met my needs. Our main router is a linksys e4200v1 and I have just recently bought another e4200v1 that should be coming in the mail soon. Originally I was thinking to set the second one up as a repeater but i have read online that my bandwidth will be cut in half and I do not want this because I am extending the WiFi for the sole purpose of gaming on the PS3. Is this correct? I was going to flash it with the DD-WRT firmware but should I make it a repeater, repeater bridge, client, etc? Just want to extend our WiFi and not lose our speed. Thanks for any help!
The only way you are going to extend the wireless and not lose 1/2 your speed is to use a wire to connect the second one as a AP. It then in effect repeats the data from the cable to the wireless so it is only using the wireless bandwidth 1 time and is on a different channel as the main router so it does not interfere.
I had seen some discussion the dd-wrt forums about using 1 radio to talk to the main router ie use say the 5g one and then run the 2.4g as a AP. Here you have 2 different radio signals one for the backhaul to the main router and the second to talk to the clients. Again the same design as a AP connected by cable but this time the cable is a dedicated point to point wireless connection. I am not sure dd-wrt actually does that though. It tends to be simpler to buy 2 boxes 1 to act as the point to point back to the main router and the second running as a AP. There are very expensive commercial AP that have extra radios built in but it is still cheaper to buy 2 consumer devices and hook them back to back.
Unless you are very lucky games on a wireless connection...even a very good one.. tend to get random loss which causes lag in the game.
Thank you so much for your help. I have tried doing what you said with the current extender router I have been using (WRT54GSv6 running the DD-WRT firmware) and I cannot seem to get it to work. I have set the extender to AP mode and put it on channel 6 because our main router is on channel 11. I connected the extender to a netgear powerline box which is working properly. One of my questions is do I want to connect the extender to powerline box using the LAN or WAN port on the router? I tried both and it still seems to not work. Another thing I came across in the settings was this virtual interface setting. Now I previously had this one set up as a repeater and was not pleased so I didn't know if I should remove the virtual interface now that I have changed it to an AP or do I need to keep that? I have attached a screenshot of this setting. Thanks in advance for any help!! Getting a headache over all this mess.
Screenshot from WRT54GSv6 running DD-WRT
had the same router and dd wrt and i got it work wireless as a "repeater bridge". the gains were minimal because you loose speed going through wireless twice latency kinda thing. i ended up just using that router as my PC's wireless network card- hard wired to the PC connecting wirelessly to the main router.
I had it set up as a repeater before but I bought a e4200 that should get here later today whenever my mail gets here but I was trying out the method of setting the WRT54GS as an AP so I wouldn't lose as much speed but it isn't working out for me. I only had it set as a repeater however, not a repeater bridge, if I set it as a repeater bridge will I gain some of that speed back?
