Question Extension cable for 4 pin chassis fan?
Killianz26
Hi I just picked up a Corsair 120MM RGB Case fan.
For the RGB I plugged it into my existing exhaust fan which has a daisy chain available so that is working.
The issue I ran into is all my sys fan headers are at the bottom of my motherboard and the power cable (4-pin) won't reach.
I plugged it into the Pump Fan header I had available at the top of the motherboard.
Is it possible to get a extension cable or something I can plug into the sysfan header at the bottom to connect it to the fan opposed to using the Pump header?
I looked on Amazon but the ones I saw looked too big?
Let me know if am missing something?
Thanks!
Make and model of your motherboard? Make and model of your case? mind sharing a link to the fan you're working with? As far as I can recall Corsair's needed a hub/puck of sorts since their connectors were proprietary like Thermaltake's fans.
