My hard drive have multiply error after i try to use a program formmater 32 i started to get a crc error on one partition then after trying to fix it my other partition got the crc error too. I try every program to fix but nothing wouldn't work. It still have the 2 portion showing it "Healthy (Primary Partition) for both but in RAW format stuck in read only and 8 unallocated. The hard drive doesn't click or make any noise It sound normal. The only thing i can't get through is the crc error and read only mode. I can't surpass the read only with the crc error in the way trying to fix it. I'm willing to do anything to fix it.
Information:
st975042 3as seagate
Serial # - j339
Interface - SCSI
Total Size - 715402
Information:
Serial # - j339
Interface - SCSI
Total Size - 715402
