Hi there,
My brother in law had his external harddrive enclosure running a 320GB sata drive via USB. He said he accidentally tripped the powerstrip on/off switch. After turning it back on the drive no longer shows in Windows Explorer, but does show up in Computer Management, but as an "Unknown", "Not Initialized" "Unallocated" drive with a capacity of 2048.00 GB. Clearly something is wrong with the drive capacity, which leads me to believe the MBR is messed up (but, you can probably guess I really don't know much about this).
The data is not irreplaceable, but an evening or two would be well spent if we could recover the partitions. There are 3 partitions I believe.
I have tried EaseUS (I've used their software in the past for other data recovery projects). I tried the "rebuild MBR" with no success, and before that I tried "recover Partition". There is also an "initialize GPT" but I don't want to start clicking things without advice.
So, any advice for what to try here?
Thanks!
-Stephen
Thanks!
-Stephen
