[SOLVED] External Hard Drive Enclosure not working
Nov 20, 2018
So my haze 3.5" USB 2.0 to sata enclosure recently stopped working and it's got my school projects and stuff and am really worried bout it. So I think something is wrong with the AC adapter thing because the yellow light doesn't come on.... Its plugged into a wall socket and was working fine until 2 days ago... Would really appreciate if anyone can help...
Also using windows 10.....Thnx
If you are lucky it may just be the enclosure.
I would remove the drive from the enclosure and attach it to the SATA data and power connectors on a desktop computer. You can then troubleshoot the enclosure later, but concentrate on getting your data back. If you have no access to a desktop for this, you can place the drive in another enclosure.
And learn from this...
And learn from this lesson that backing up important data is a very good idea.
