I made a very big mistake
so last few days i have been making a lot of mistake such as using a used window pro key which to revert i had to delete everything of my computer and then restore it back as it came.
NOW i made one very big mistake i have
accidentally turned my brother External Hard Drive to Recovery Disk
here is what happened since i restore my computer because of the windows 10 pro key failure i decide to create 2nd partition on my brother external drive which already had data on it. So i created second partitions on external hdd abut 30 gb and then i started the process transferring the recovery data from my computer to the second partition that i created. When it started it deleted every thing on the External HDD then created a new partition of 32 gb and rest of data became unallocated data which was around 920 gb and he had a 300 gb of data on it and i had window 8.1 image backup and 15 gb of my data on it also so i lost it all and then i did not i had to keep external HDD on raw format so i changed it back to ntfs i used easyus recovery wizard trial to see if my data is still there. I see the data that my brother had on the drive and my window image backup there but i don't see my data that i put the before restoring my windows to factory settings.
I just want know how can i restore everything beside the window backup because even if i get it back it will be corrupted?
And also how can I create a recovery drive on the external hard drive without losing my data already on the external drive?
