Question External monitor is running solely on dGPU ?
Dec 16, 2020
49
The laptop is MSI Alpha 15 with RX Vega 10 integrated GPU, and RX5500M dedicated GPU.
The problem is, as soon as I run 2 monitors at the same time, the system allocates each GPU for each screen. For example, I have 10% usage of dGPU and 10% of iGPU.
It can't be because HDMI only works via dGPU, because when I disable the internal screen and use external as the only and main screen, then it runs on GPU.
How can I solve this?
Thank you.
