B BenBorchers Commendable Jul 13, 2016 8 0 1,510 Oct 30, 2016 #1 Can I make a power switch for a monitor external or is it not possible? Thanks
Solution USAFRet Oct 30, 2016 BenBorchers : Can I make a power switch for a monitor external or is it not possible? Thanks Easiest way is to buy a $5 power strip. Plug the monitor into that, and use the switch on the power strip.
USAFRet Titan Moderator Mar 16, 2013 179,822 22,280 184,590 Oct 30, 2016 Solution #2 BenBorchers : Can I make a power switch for a monitor external or is it not possible? Thanks Easiest way is to buy a $5 power strip. Plug the monitor into that, and use the switch on the power strip. Upvote 0 Downvote Solution
mcnumpty23 Polypheme Jul 15, 2011 15,518 1 66,960 Oct 30, 2016 #3 can you? yes of course you could replace the original switch/button and make it external but why would you want to? Upvote 0 Downvote
