We are looking to add an external monitor to an HP OMEN 17t-ck000 Laptop, but after doing all the research, I don't know where to start anymore. Laptop specs are:
What makes it partly confusing is that when I look at the display settings, it shows 1920 x 1080 recommended. So do i stick with a 1080 monitor, or upgrade to a nice 1440? We don't do any real hard-core gaming on it, and im not even sure which resolution I should be looking at primarily. Thank you.
- CPU: Intel® Core™ i7-11800H (up to 4.6 GHz, 24 MB L3 cache, 8 cores, 16 threads)
- GPU: NVIDIA® GeForce RTX™ 3070 (140 W) Laptop GPU (8 GB)
- RAM 16 GB DDR4-3200 SDRAM (2 x 8 GB)
- Display: 17.3" diagonal, QHD (2560 x 1440), 165 Hz, 3 ms response time, IPS, micro-edge, anti-glare, Low Blue Light, 300 nits with 16:9 AR
