Question External mount GPU fan
Lars Ericson
24
I bought a Tesla K80 for some deep learning work. It doesn't have a fan and I want to jam it in my rig. This guy has an intriguing solution that involves a glue gun and some tin foil:
View: https://www.youtube.com/watch?v=UcyP3ASRgBc
I'm going to start with that, but then I saw this, it's a tiny picture but note the big honking square fans mounted on top of the back of the expansion slots:
https://www.supermicro.com/products/system/4u/7048/sys-7048gr-tr.cfm
I Googled for a long time and couldn't find anything like these. Is there a name and a vendor for this kind of fan? I realized there's not a big market (all purchasers of used obsolete server cards trying to jam them into consumer PCs), but still.
I imagine those are standard fans for racked servers with custom brackets from whoever built that chassis. You could certainly track down a rack chassis and get some high RPM fans to replicate the environment it is supposed to go in.
Being a dual GPU board, not a lot of things that would fit it otherwise. Possible a Titan Z cooler will fit it? Might be some waterblocks that might do the trick if you don't mind getting into that.
Otherwise I would just prowl around on ebay or amazon and look for server parts.
Maybe enough room for two all-in-one CPU coolers?
https://http2.mlstatic.com/placa-de...cb-D_NQ_NP_721033-MLB27726103923_072018-F.jpg
Here is a picture of the SuperMicro box and it clearly shows the red fans positioned over the GPUs externally, plus 2 not over the GPUs:
http://www.broadberry.co.uk/gpu-workstations/teslastation-7049gp-trt
and here on a SuperMicro the exact same fan model but not over the GPUs
https://www.supermicro.com/a_images/products/views/7048GR-TR_rear.jpg
I'm going to try Google image search to find those distinctive red blocky fans.
Another solution involves printing a 3D part for $30 and attaching a fan on the inside edge of the card:
https://www.cgtrader.com/3d-print-m...ia-tesla-k80-v100-m40-cooling-fan-shroud-duct
Actually here is a solution which eliminates need to 3D print a cooling fan shroud. I may do both DIY solutions: tinfoil fan outside case and this adaptation on inside end of the card:
View: https://youtu.be/jPIBqQErc3o
