I am planning on building my first computer. I want to build it inside of an HP Silimline Case ( http://support.hp.com/us-en/document/c01623239 ) which I know isn't the best of choices but I still want to do it. I choose the following hardware..
https://pcpartpicker.com/list/TCpWjc
Intel Core i5-6400
ASRock H110M Mini-ITX Motherboard
Crucial 8GB DDR4 Memory
ADATA SP900 256GB SSD
MSI GeForce GTX 1050 2GB Low Profile
The only issue I am running into is the power supply. The 1050 has a recomended minimum of a 300 watt power supply. The only power supply form factor that this case will support is a TFX power supply, most of these have bad reviews and die within a few months.
I was wondering if it were possible to buy a Corsair SF450 ( https://www.newegg.com/Product/Product.aspx?Item=N82E16817139156&cm_re=corsair_sf450-_-17-139-156-_-Product ) and turn it into an external power supply for this build.
Thanks in advanced 😀
Intel Core i5-6400
