Question External SATA drive won't mount using SATA to USB converter
eco_bach
70
I have one of these SATA to USB converters https://www.amazon.ca/Converter-External-Universal-Function-Software/dp/B00EHDTRJ6/ref=asc_df_B00EHDTRJ6/
I'm trying to back up old SATA drives removed from a few old Macs. Success on 2 drives although I found I needed to mount in a Linux (Ubuntu) desktop. Had no luck in Windows most likely because these drives are HFS formatted.
On my 3rd drive however no matter what I do can't get it to mount. The one main difference is that this drive also has a 4 pin Molex I assume for power.
Will I need to supply power to this drive before I can mount?
USAFRet
128,917
5,105
164,940
19,996
What type of drive?
If it is a 3.5" HDD, that USB adapter will not work. That drive needs 12v as well as 5v.
USB can only supply the 5v.
EDIT:
I may be mistaken. That one does have a wall plug.
