External Sound Card and speakers & woofer
Corwin65
Admirable
It seems from your PM that your needs are for music production.
Since that is the case, I would be looking at audio interfaces. Some of them even have Midi built in.
It's amazing what $150.00 or less can get you today. I have a $30 interface (Behringer) a $50 interface (also Behringer) and 2 Focusrite interfaces the Solo and 2i2.
Give them a look.
Corwin65
Admirable
No, midi sound is now done through the use of VSTi's.
Virtual Studio Instruments are found in the DAW of your choice and free and paid ones can be downloaded.
Sep 19, 2018
7
Corwin65
Admirable
Again, it seems you are out of touch with current systems. Windows PC's are used all the time for recording and performance. The software and hardware work well.
You are asking about a soundcard for a PC with Midi so you are relying on a PC for performance. While the best piece of hardware is the performer, I'm not sure what it is you want.
Tell me specifically what your use will be and maybe I can help you with a solution that actually fits your needs.
Sep 19, 2018
7
Similar threads
