External Sound Card for DT880s
OMNIBOSS
13
Hello i plan on getting a pair of 250ohm dt880s and was wondering if anyone could recommend a good external sound card to get the most out of them. Thanks!
I use this Fiio E10 USB DAC/AMP (external sound card) with my 250ohm DT 770s. I have around 2 dozen different sets of headphones and a half dozen DAC/AMP combos (up to $800) and honestly, for $62 there is no better deal than that E10. It pumps out plenty of clean power, even for my 600Ohm DT 990s and I find myself using it more than any of my other setups (it just plugs in via USB and it's smaller than a deck of cards). Give it a try and you wont be disappointed! Hope this helps!
Ya i heard the e10 was a good dac, and ill be sure to look it up. Thanks!
