External Sound Card to go With Corsair SP2500
zed77ultra
57
I am planning on buying Corsair SP2500 speakers, but after doing some research realized that to reach their full potential they need a high quality sound card. I have a laptop so I cannot replace my sound card, so could someone suggest a good external one under £100?
I don't need any surround sound compatibility - just the stereo. ls it possible to get a cheaper sound card with only stereo sound?
yes there is , both of these will also work with stereo however as a cheaper alternative
there are many sound cards such as these ,
http://www.amazon.co.uk/Creative-Soundblaster-Play-Sound-external/dp/B0028RZ23I/ref=sr_1_4?ie=UTF8&qid=1399713817&sr=8-4&keywords=external+sound+card
http://www.amazon.co.uk/Creative-Labs-70SB129000002-Sound-Blaster/dp/B0042RUERG/ref=sr_1_19?ie=UTF8&qid=1399713893&sr=8-19&keywords=external+sound+card
there are many alternatives here
http://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=external+stereo+sound+card&rh=i%3Aaps%2Ck%3Aexternal+stereo+sound+card
But would the sound quality be the same? Could you give me some stereo sound card options that match the quality of the 7.1/5.1 cards but are cheaper?
The Xonar and Creative x-fi put out the best sound quality IMHO , the first two i showed you have great software and will work with stereo , the small cheap sound cards are just that but will work but without the quality and software ,
I have used both cards and am currently using this card
https://www.youtube.com/watch?v=kUeDPgxOiFQ
after 2 years still works perfect and love the flexibility and sound control and quality
So are you saying that high quality sound cards support surround, and it is hard/impossible to find a stereo only sound card that can give sound as good as a surround supporting one?
