External Storage stripped screw help
kevikevs244277
good day.
I am currently having trouble with my external drive and as I've researched, I need to put the reading pin back to "parked mode" so I tried opening my drive. Unfortunately, as i'm trying to get the screws off,
one suddenly stripped off.. Here is a picture of the screw.
I've tried different things already like, the rubber band, glueing the driver and the screw together..
any ideas on how to remove this?
I don't have a dremel tool to make a groove for a flathead.
those are small eye glass key screws. local auto parts store should have a cheap set. if you can find one that fits for 1.00 use appoxy glue the screwdriver into the screw see if you cna turn it out.
