I have a "Seagate Expansion Drive 2TB". About two or three days ago I guess it stopped working as I have only realized today that it just isn't turning on at all or connecting no matter what I do. I tried other cables as I have a Western Digital External, a USB hub and phone connectors as well.
I took my friends advice to open it up and plug it in internally as he said the board for it may have just died out. It seems he may have been correct as I have connected it internally with SATA 6GB/s cable and the power cable to the PSU. It spins up fine while also connecting with no problem.
The only problem I have now is that it says I need to format it to access it. Under device manager it now goes by its model name "ST2000DM001-1E6164" instead of its original device name "Seagate Expansion Desk SCSI Disk Device"
Here it is listed as Drive "( E: )". Before it was listed as Drive "( I: )".
http://i.imgur.com/5Vd2sNB.png
I am currently at a loss at the moment and have over 1.6TB of data on it that means a lot to me. (Family pictures, videos, photoshop files, backup files etc.)
Is there anyway to make it go back to been its normal drive at all?
Edit #1: I forgot to mention that when it was still in its external case. I plugged it into the front USB 3.0 panel on the PC case and it disconnected all the USB devices except the ones not connected to the USB 3.0 card. The USB 3.0 card is slotted into the x1 PCI-Express slot on the motherboard. I unplugged it to see if the others would reconnect but they did not. I had to turn the PC off and re-slot the card for them to be able to reconnect.
