Hello,
Basically what happened was I bought parts for a custom build (ASUS P6X58D Premium, Intel i7 950-based) and had a computer repair shop put everything together. I didn't have a CD drive because I was planning to install the operating system (and do all my data transfers) via USB which would make it much more convenient because this was going to be a music production computer, so I really had no need for a CD drive in terms of distribution or data transfer.
So I get ready to install Windows XP through USB on a regular pen drive. For some reason BIOS isn't picking it up, so I try another pen drive, same thing. (Later when plugging these into another computer they don't work so I figure I sacrificed them with the formatting I had to do to put the Windows XP ISO file on them). At this point I'm guessing it must be that I do in fact need a CD drive for this particular motherboard for some odd reason, so I order one and install it, install the operating system and then I get ready to transfer data (programs and project folders) over to the new hard drive once XP is up and running, only the USB isn't registering at all. I get the "Device malfunctioned" thing in the lower right-hand corner. So, based exactly on what it says @ http://www.usbcheck.net/FAQ.php under "So, what's the problem," I do the whole 'human nature' thing and plug in my only two external USB hard drives, the second containing literally EVERYTHING. 13 years of work basically, completely irreplaceable data.
Now, when I try to plug them into another computer I get the 'USB Device Malfunction' error and 'Unknown Device' in the Device Manager (they both still turn on and light up, they're just seemingly not accessible on the other computer). My basic hope and overall question is essentially whether or not I'm doomed. Is this like someone getting struck in the head by lightning and losing all their memory? Or is there hope for data recovery?
P.S. Upon opening the case after doing this research I verified that the polarity of the USB front connector was improperly done (- went to + and - went to +). Too bad I didn't know to notice this kind of thing when installing the CD drive.)
THANK YOU to anyone who can shed light on this.
I guess I should also ask while I'm at it if the motherboard or any devices connected via PCI are potentially trashed.
More information: One hard drive is a WD My Book 2 TB and the other is a Seagate Freeagent 1 TB.
