Question External USB storage problem.
knowledge2121
404
I connect a USB storage device to my USB port and then leave my computer on and then go downstairs to do something, when I come back after some time, I try to eject the device through the "Safely Remove Hardware and Eject Media" icon in the right bottom corner but strangely when I left click it the context menu doesn't popup....what is the cause of this ? I have tested different USB flash drives and external USB HDDs ... same results....
onespeedbiker
Respectable
Apr 13, 2019
2,331
176
2,390
133
Try disabling your antivirus.
Go to the Device manager, double click Universal Serial Bus Controllers and uninstall each of the devices under the USB Controller
if that doesn't work removed the USB, reboot then plug in the USB and see if, It's safe to remove the drive is working.
