External USB2.0 HDD enclosure problems.. Please Help!
Evan
58
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have recently bought a second 2.5" hdd for my laptop, formatted and now
running win XP sp1 on it, however when i plug in my external HDD i get :
"found new hardware - Atapi-6 bridge controller"
windows tries to install the software for the device but in the end it stops
saying that the drivers could not be found...
i used this external drive before and it never needed any software install,
i used to plug it in and it would show up in explorer...
at the moment, i have my primary internal 2.5" as device 0 (jumber settings)
secondary internal 2.5" HDD as device 1
and the external HDD i believe is set to cable select (i could be wrong tho)
if anyones has a clue on what could be wrong please help me...i have very
important database files on the external hdd that i need to transfer to my
new internal hdd.
Thanks in Advance
G
Guest
Guest
Usually drives have to be set to master when used in external enclosures..
Tumppi
Reply to group
Most learned on nntp://news.mircosoft.com
Helsinki, Finland (remove _NOSPAM)
(translations from FI/SE not always accurate)
"Evan" <Evan@discussions.microsoft.com> kirjoitti viestissä
news:DD41E9A5-79FF-4345-8A4C-6CD81BDFD2A9@microsoft.com...
stops
install,
settings)
tho)
> new internal hdd.
> Thanks in Advance
G
Guest
Guest
I just got a Grandtech (tw) USB to IDE adapter, it does not
work with a WD disk unless the jumper is _not_ inserted at all.
Jumper in master or any other position causes it to stop working.
--PA
"Thomas Wendell" <tumppiw_NOSPAM@hotmail.com> wrote in message news:u7qNeivvEHA.200@TK2MSFTNGP11.phx.gbl...
> Tumppi
> Reply to group
> stops
> install,
> settings)
> tho)
> > new internal hdd.
> > Thanks in Advance
