A a7928671 Reputable Jul 21, 2014 9 0 4,510 Jul 21, 2014 #1 Hi, Im having a problem with my 1TB external WD HDD. It is not showing up when I open up my computer. However the white light is flashing, but I cant seem to be able to see it under my computer. Im using Windows XP, thanks.
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Jul 21, 2014 #2 Have you downloaded and installed the drivers for it to your pc? Upvote 0 Downvote
A a7928671 Reputable Jul 21, 2014 9 0 4,510 Jul 21, 2014 #3 Well the windows installed drivers automatically. Oh and btw...it is WD 1021 HDD. Upvote 0 Downvote
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Jul 21, 2014 #4 Does it show up in Control Panel, Device Manager? Upvote 0 Downvote
A a7928671 Reputable Jul 21, 2014 9 0 4,510 Jul 21, 2014 #5 Yes under device manager I can see it. It also shows on safetly remove hardvare as USB mass storage device. Upvote 0 Downvote
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Jul 21, 2014 #6 Can you see it in Windows Explorer? Upvote 0 Downvote
A a7928671 Reputable Jul 21, 2014 9 0 4,510 Jul 21, 2014 #7 If you mean under my computer no, if thats not what you mean please explain me where do you mean. Upvote 0 Downvote
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Jul 21, 2014 #8 If it shows up in Device Manager, it should show up in Windows Explorer under Computer. Is the drive formatted? Upvote 0 Downvote
A a7928671 Reputable Jul 21, 2014 9 0 4,510 Jul 21, 2014 #9 Well it does show under device manager, but I cant see it under my computer. It is not formatted, there are files on it that I need. Upvote 0 Downvote
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Jul 21, 2014 #10 If there are files on it then it must have been formatted. If it shows up in Device Manager as working then you should see it under Computer. If you disconnect it's usb cord, does Windows make the disconnect noise? And the connect noise when you connect it's usb cord? Upvote 0 Downvote
A a7928671 Reputable Jul 21, 2014 9 0 4,510 Jul 21, 2014 #11 Well yes there are some files on it already that I would like to save. Yes I do hear sound when I plug it in and out. Upvote 0 Downvote
I i7Baby Titan BANNED Jul 25, 2012 44,080 2 106,960 Jul 21, 2014 #12 Then it should appear on Windows Explorer. In fact a screen should pop up asking if you want to view its content. Have a look here - https://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/hardware_installing_overview.mspx?mfr=true Upvote 0 Downvote
A a7928671 Reputable Jul 21, 2014 9 0 4,510 Jul 21, 2014 #13 Yes I know, however I dont see it on explorer, and the pop up window doesnt show. Upvote 0 Downvote
Markkk Distinguished Jan 2, 2012 447 0 18,960 Jul 21, 2014 #14 Under Computer Management / Disk Management Is the Drive Active? - If not right click mark as active Upvote 0 Downvote
