External WD passport not read on PC but perfect while connected to Samsung TV
Konsoul
Hello,
My external hard drive is up to no good! I've backed up most of it. Last week Windows 7 enterprise stopped reading it. Asked for format drive, of which I declined. My computer sees the drive as d:/ but I can't access files. It's NTFS. I reinstalled Windows 7 after this and still the same problem. It's recognised as d:/ but appears to have no file system. I've tried recuva and it doesn't recognize the drive has a file system.
THEN... I plug the drive into my TV, a Samsung and it reads the file structure and files perfectly. Any ideas on how to get my files off the hdd or readable again, before I lose the music I've got since my last back up? Only 3 months, but it's podcasts and apps that take ages to download.
Thanks for reading and any advice
Sincerely
Konsoul
Try giving the external hard disc a definite letter as a drive, e.g Drive "W", it may then be recognised.
I had same problem on a WD external drive, it was allocated to one computer as a "hard drive" with property for "quick removal" (I think) reset the drive letter and removed the "easy removal" , so it MUST be removed via USB removal. This solved the problem.
So, it looks like I'm an amatuer! I went through all the advice, and even got it to be named G:\, but can't access files on it. It repeatedly asks if I want to format it! It's not showing up in explorer as G, but the Computer Management centre sees it as Disk 1 954GB space. I have been asked to initialise it to 2 seperate ways, but got an error no matter what choice i make.
In Device Manager, there is a yellow exclamation at Other Devices for the Mass Storage Controller. I've downloaded the software SES driver from WD, which allowed me to work on the driver letter aspect, maybe i will continue repairing the SES and see what happens.
Thanks.
Hi Konsoul,
Are u able to solve ur problem?
I am also facing the same issue with my WD 1TB external hard-disk. Plz share, how u got it fixed, if U..
I tried a lot, but could not get mi HDD read read with windows.
Plzzzzzzzzzzzzzzzzzzzz
EMAIL REDACTED - SS
Thanks//
