I have successfully shunt modded a pcie slot powered gtx 1650 zotac low profile model card.
Normal card wattage in gpu-z is about 66-68w
So far the highest ive tested is 75w
How much higher would be reasonable for me to try going for? 80w? 90w? 90w would be 15W above the 75w pcie spec
my friend has done a shunt mod on RTX 3090 with about 100-105w power draw through pcie slot!
