G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
I seem to be having CPU temperature trouble. I have an
Athlon XP 2800+ on an ASUS A7N8X. I assembled it myself,
buying a Retail (boxed) Athlon processor that came with
the fan.
It has been mysteriously turning off -- checked the fans
and all are working fine (at least apparently)
The hardware monitoring section in the BIOS setup shows
temperature of 70 degrees Celcius most of the time (it
*never* goes below 68), and often going up to 80 - 82
degrees. The CPU fan is spinning at 3800 RPM, according
to the monitoring software.
I wonder if all this is normal. My wife's machine is an
Athlon XP 1700+ on a GigaByte motherboard (I think). Also
assembled by myself, with a Retail Athlon that came with
the fan. Her machine shows a normal working temperature
of 50 degrees Celcius, and the fan spins at 5000 RPM.
So, my two questions:
1) Are the values on my PC normal?
and
2) What should I do? Should I replace the fan? If so,
what brand/model would you recommend? Or should I
go straight and replace the CPU with a 3000+ or 3200+
with its own brand new fan? (not sure if the increase
in performance would justify spending the extra bucks
for the processor upgrade -- OTOH, perhaps these CPUs
are quite inexpensive these days?)
Right now it's been almost 24 hours since the last time
it powered down, but lately, it's been doing it at a
rate of two or three times a day!!
Thanks for any advice,
Carlos
the fan.
and
Carlos
