Extreme spontaneous lag spikes in Counter-Strike & CS:GO + Laptop Adapter Issues
Jan 18, 2015
16
Been struggling with this for some time; whenever I attempt to play Counter-Strike I encounter severe lag spikes for 1/2 - 2 seconds at a time. Running Valves net_graph has shown a sudden spike in latency (not fps related at all) and then settles back down to normal. This has become extremely frustrating as I have just about exhausted every single solution I could think of.
Attempted fixes:
-pulled out/plugged back in modem/router/adapter
-Tried out three different wireless cards ranging in speed from G to N, one of which was brand new, all experienced similar problems
-Made sure all drivers were up to date
-Tried out USB and PCI adapters, tried multiple slots for both, same problem
-Updated BIOS software/firmware
-Bought a brand spanking new router and updated firmware. Router model: NETGEAR WNR2000v5, firmware edition V 1.0.0.26. (This, of course, has led to another problem I will explain below)
-Made sure that all versions of CS have been added to the Exceptions list on Windows Firewall
-Validated Counter-Strike files
-Reinstalled Counter-Strike
-Reinstalled Steam
-cleared out some clutter near my desk to improve reception
-Made sure that my adapter is set to Multimedia/Gaming Mode in Device Manager (<<< this has been the most beneficial fix so far. It has reduced the frequency of spikes by maybe 70%-80%.)
-Made sure that my adapter is running CAM (constantly awake mode) in Device Manager
-angled the dual antennas in my current adapter (PCI, Wireless-N) to ensure they are directed towards the router
-ran multiple tests on speedtest.net and pingtest.net, all results were good to excellent across the board
-pinged multiple websites from command prompt, no lost packets detected over multiple runs
-switched between static and dynamic IPs
-tried to open ports- never had much success with this, and I honestly don't think it would matter
-probably a couple other things I can't think of at the moment
At this point, my blood is really starting to boil, to say the least. Literally the only thing left I can think of is calling my ISP and asking them to reset my connection... whether or not this will do any good is anyone's guess.
For reference, I am running:
Windows XP Professional Service Pack 3
Intel Core 2 Duo E6600 2.4Ghz
Nvidia GeForce 7900 GS
2 GB RAM
40GB + 250GB HD
MSI P6N SLI Platinum mobo
AZiO AWD102N Wireless-N PCI Adapter
On very low patience and questioning why I even bother with computers anymore
The next problem this has developed is that my laptop (~5 years old) is not able to connect to my router; I am using Windows Wireless Config and every time I attempt to connect I get an error stating that my machines wireless hardware is incompatible. Correct me if I'm wrong, but aren't new routers backwards compatible with G adapters? That machine is a DELL Inspiron 1545.
Thank you for reading. I have never posted on Tom's Hardware in the past but these forums have been an excellent resource for me in times of need, and I am confident this time will be no different.
Looking forward to your responses.
cs go - http://www.game-debate.com/games/index.php?g_id=2323&game=Counter-Strike:%20Global%20Offensive
Maybe your laptop has trouble playing it. Put your laptop details into that screen and see what it says about how well you can run the game.
Also check what CPU temp you are getting. The biggest problem with laptops is overheating. If so, remove the covers and blow the dust out. And use a laptop cooler.
If you are having problems with your laptop wifi card you can always use a usb one eg http://www.newegg.com/Product/Product.aspx?Item=N82E16833166068
Sorry, I guess I forgot to specify: I am encountering this problem on a desktop machine (The one running XP Pro). I am encountering issues with wireless on my laptop, however.
Laptop specs:
Windows Vista 32 bit
Intel Pentium Dual Core Processor 2.0Ghz
4GB RAM
250 GB HD
Intel Onboard Graphics
Initially, I wanted to see if it was an in-game issue by running CS 1.6 on my laptop and comparing the network quality (CS:Source and CS:GO lag quite a bit, but I was probably going to run them anyway and monitor the network quality of them as well) However, seeing how I cannot access my own wireless, there isn't really any way of knowing if it's a problem with Counter-Strike or a problem with my internet. I considered using one of my neighbor's wireless, but only one is unsecured and the quality is quite poor and intermittent at best. Besides, I'm not a big fan of stealing other people's wifi...
OK, so I went ahead and ran PingPlotter for about 90 minutes. Within that time frame, there were three lag spikes up to a maximum of 1241 ms. This kind of narrows it down to a hardware issue, or so I am led to believe. This raises an interesting question: since I experienced similar lag spikes with multiple different adapters, is this a mobo issue or wifi related? I guess I could run PingPlotter on a different machine (without Counter-Strike but still able to access my wireless network) and see if this issue is present there...
any insight is appreciated
Went ahead and ran PingPlotter an another machine running off my wireless. Wireless is healthy- no ping spikes or anything. It seems this issue is indeed limited to this machine. Does anyone know what could be causing random spikes in excess of 1000 ms in ping?
Additionally, any help on how to get my router to be backwards compatible with my G adapter on my laptop would be most appreciated.
My build has been posted above, but I will gladly repost:
Desktop Specs:
2 GB RAM
40GB + 250GB HD
Laptop specs:
4GB RAM
250 GB HD
I must stress, however, that with the same builds I was able to run these programs with no problems before I started to encounter this problem. As I mentioned above, PingPlotter showed a regular, consistent increase in ping over a 90 minute period with latency over 1200 ms. I was able to get a wireless N USB adapter to work with my laptop, and ran PingPlotter on that machine as well. Strangely enough, I also experienced regular lag spikes, but on this machine they did not exceed 250 ms.
So, to recap: on desktop: regular, insane ping spikes well over 1000 ms
on laptop in my room: (3rd floor; router is located on first floor) regular spikes not exceeding 250 ms
on laptop directly below the router: no lag spikes detected
I said "Also check what CPU temp you are getting. The biggest problem with laptops is overheating. If so, remove the covers and blow the dust out. And use a laptop cooler."
Laptop and desktop connected to router by ethernet cable or wifi?
What router (make and model)? How far from laptop and desktop?
... I am not encountering this problem on my laptop, and I thought it was fairly obvious that I am on wireless... I also listed the router information and the relative location in the first post. I am getting tired of re-posting this information, but here you go:
"-Bought a brand spanking new router and updated firmware. Router model: NETGEAR WNR2000v5, firmware edition V 1.0.0.26."
"So, to recap: on desktop: regular, insane ping spikes well over 1000 ms
on laptop directly below the router: no lag spikes detected "
Alright, so I was able to connect to an unsecure network and run pingplotter. I am still experiencing severe latency spikes well over 1000 ms, so I'm guessing it's not a problem with my network, but a problem with my PC itself, but NOT the wireless card(s). Could this be a motherboard issue or something along those lines? If I had a long enough cat5 cable to run through my house I would but that's not an option right now.
I am not an expert but lemme tell you what I think. I am experiencing severe lagspikes in CS:GO after every single steam patch so I cant play competitive at all for some days (I broke my keyboard today as anger management exercise, I was so much fed up), but then the problem goes away by itself. I monitored the bandwidth usage today and it shows that my comp receives info from steam servers in abundance. I suspect that after the patch either steam or CS:GO finishes the patching 'on the go' as you play, either receiving and installing remaining parts of the patch or fine tuning CS:GO based on the new steam environment -- steam or valve probably intended this to avoid disruptions in gaming experience from lengthy patching but I would have preferred a half day solid patching instead of this long dragging lagg feast, if they asked me. anyway, it is also possible that due to the increased traffic on CS:Go and steam servers resulting from the new patch my comp cant connect to the servers properly and my packets are redirected all the time, hence might the spikes originate from. dunno, I have a degree in history, not IT =) but commonsense hints me the above.
