well i wanna watercool my very expensive build so that i can overclock more and keep my temps low here are the spec of my build
intel core i7 965 extreme edition 3.2 GHZ
3xEvga gtx 285 1 Gb FTW Edition
Asus rampage II lga 1366 extreme
LIAN LI PC-P80 Black Aluminum ATX Full Tower Computer Case - Retail
here is what i plan to get
i am going to make 2 loops because i am going to water cool the entire system,so any problems????
*** HOT *** Swiftech APOGEE GTZ Ultra Extreme Performance Universal Water-block
- Water Block Hold-down Plate Add Swiftech Apogee-GTZ-Ci7 Hold-down for LGA1366
3x*** NEW *** Koolance VID-NX285 (GeForce GTX 285) [no nozzles] *** NEW *** Koolance VID-NX285 (GeForce GTX 285) [no nozzles]Backorder
- Nozzles Add Nozzle Pair, G 1/4" Swivel Angled [13mm, 1/2"] NZL-L13KG
2xAlphacool Laing DDC-Pump 12V Ultra Water Tank
- Fitting Size 1/2" Barb for 1/2" ID tube
20x Feser Tube Active UV Hose - 1/2" ID (3/4"OD) Anti-Kink Tubing - UV Blue
20xKoolance Resuable Hose Clamp [19mm, 3/4" OD] - Black
2x *** NEW *** Feser X-Changer 360mm Xtreme Performance Radiator - Thermochill Killers!
- Shroud Add Feser TFC Xtender Shroud(s) - Blue
2x EK-Multioption RES 400 Rev. 2
- Reservoir Accessory Add EK-ANTI-Cyclon
2x Feser One F1 Cooling Fluid - Clear/UV Blue - 1 Liter
12xScythe S-Flex 120mm Fan - Ultra High Speed (SFF21G) (i know i need only 6 but i will get 6 more in case any of them stopped working so that i can replace it quickly)
