I am having problems with my PSU the Seasonic Prime Fanless TX-700 (SSR-700TL) 700W: not as long as a month ago it started to makes coil whine noises. Before that it used to be quieter than my old GPU, but now it is the other way around. Usually the PSU in question starts pretty much inaudible to my very sensitive ears but after dozens of minutes it starts producing unbearable high frequency sound. And this PSU has no more than half a year of usage and is it so high-end that Seasonic gives whole 12 years of warranty for it
I know that this is an issue to be taken most likely with manufacturer of that PSU i.e. Seasonic and I am making an inquiry with them about this right now - however there is a real plot twist
I also have a previous version of this PSU, the Seasonic Platinum-520FL Fanless (SS0P-520FL2 F3) 520W. When I bought that new one 700W, the old 520W was working A-OK. But now when I switch from using one to another it is all the same: they seem OK at first but after a while an extreme coil whine starts [always sounding exactly the same from what I can tell]. I even changed later on the cables form those new [700W] ones to old [520W] ones, although the all look the same to me. So this would point out to other components as culprits, right- assuming that they can affect the inner-workings of PSU, right? Well- can they? Because: how else could that old not connected to anything PSU laying on a shelf in other room get damaged in the same way as the new one being used constantly? Or maybe it did got damaged the minute I connected it to my machine after half a year of inactivity- by such hypothetical culprit?
But on the other hand after a period of the PC being turned off for few minutes that noise is absent also for a few minutes when I turn on my machine back
And so, the question here is: is it possible that somehow my motherboard [Gigabyte X570 Aorus Ultra rev. 1.2 with BIOS v. F30] is affecting my PSU? And if yes would it this problem [with mobo] be detected with some other unit / model of PSU if I send it to Gigabyte for a check to up - or would I have to send it along with one of my PSUs?
Or what else could cause this? The power grid itself? Neighbors upstairs running some hardware 24/7 that is affecting my hardware only after some time it stars working? CPU? GPU? Cables after all?
