So, I just built my new rig, and this will be my first time attempting to overclock, so I figured I'd run this problem by you guys before I start. Problem is, everything is reporting ridiculously low core temps on my CD2 E6600. As you can see, coretemp has both cores in the teens when idling (I believe the incorrect frequency is due to speedstep):
Speedfan reports similar results...
My room is a bit on the chilly side, but I really doubt the ambient temperature is lower than 18 degrees Celcius, and I know that the core temps should be significantly higher than that. However, when I put the processor under load, both cores jump up about 15 degrees into the low 30s as expected. I'm a little hesitant to start overclocking if my temperatures are being reported incorrectly. Any thoughts?
Just for the sake of information, I'm using a Gigabyte GA-P35-DS3R motherboard with a C2D E6600 (haven't overclocked yet, and I believe its running at 1600 Mhz when idle due to something similar to speedstep on my mobo.
