Hi all,
I have a gaming PC which had been running perfectly fine and playing all games at maxed settings with usually over 100fps, except for PUBG which is usually a bit lower but now for some reason after playing fortnite perfectly fine a little while later my FPS is extremely low in PUBG and other games and does not reach above 20FPS which is insane. My gpu is a nvidia gtx 1070 8gb and my cpu is a ryzen 2600x, I also have 16gb of memory. This PC was custom built and tested for me and was working perfectly for the last few days without any issue until now.
I've looked at task monitors performance while playing games such as pubg and cpu nor gpu usage ever reaches above 20% when it used to be much higher especially for the GPU. Also I'm not running out of memory either as I have 16gb.
I've tried mutiple restarts, uninstalling geforce game experience, running a malware bytes scan (nothing found at all), changing nvidia control panel to high performance, changing physx to choose the 1070 instead of auto and nothing helps. I've even dropped graphic settings ingame to the lowest and seen 0 performance increase. Also drivers are updated, temperatures are fine and fans are running fine to my knowledge. Also I don't know if this is relevant but task manager says my cpu speed is 0.54Ghz when my base clock should be 3.60GHz.
I figure for some reason the cpu or gpu are being engaged while playing the game for a reason I cannot figure out. Any help would be VASTLY appreciated.
