Yup, common sense.
Take a moment to think things thru. U will be amazed what you can come up with.
For example...
-My room temp is 25c
-My cpu requires a heatsink. Why? Because it creates HEAT.
Using those two simple facts we draw the following conclusions...
At rest (ie turned off), each individual component in my computer system should be 25c. Yes metal FEELS colder, but thats just physics.
Now as soon as we apply electrical current to a device, like a cpu, its gonna generate heat. Hence the need to dissipate that heat via a heatsink. So... this device that generates heat cannot POSSIBLY be colder than room temperature, and certainly nowhere NEAR freezing.
If all else fails crack the case open and feel the side of the chip or heatsink. If it doesnt feel freezing, it probably isnt.
