K Kishan25 Distinguished Apr 13, 2015 222 0 18,690 Nov 20, 2017 #1 The Asus Maximus X hero has a ethernet port labeled as a LAN port. What is that? is that just a regular ethernet port? Can i connect it to my router for wired connection? https://www.asus.com/us/Motherboards/ROG-MAXIMUS-X-HERO-WI-FI-AC/
Solution ThatVietGuy Nov 20, 2017 LAN port and ethernet port are the same thing. It is for connecting directly to your modem/router with an ethernet cable.
ThatVietGuy Titan Nov 6, 2007 11,726 318 70,240 Nov 20, 2017 Solution #2 LAN port and ethernet port are the same thing. It is for connecting directly to your modem/router with an ethernet cable. Upvote 0 Downvote Solution
K Kishan25 Distinguished Apr 13, 2015 222 0 18,690 Nov 20, 2017 #3 ThatVietGuy : LAN port and ethernet port are the same thing. It is for connecting directly to your modem/router with an ethernet cable. also this board comes with wifi, but do i need antennas for it or no? Upvote 0 Downvote
JoeMomma Distinguished Nov 17, 2010 860 2 19,360 Nov 20, 2017 #4 Yes. LAN means Local Area Network. Ethernet is the type of wire / plug. You do need WiFi antennas, They should have come with the motherboard. Using an Ethernet cable is usually faster and more stable than wireless. Upvote 0 Downvote
