Eyefinity 32 middle monitor with 21 outside
moldyglint
44
I was wondering if it is possible to use eyefinity with a 32" middle HDTV, and two 21" monitors for the outside. I know its a huge difference in size, and that the resolution needs to remain the same on all three monitors ( right now i only have the 32" and one 21", both resolutions are at
1360 x 768) would it be worth buying another 21" for eyefinity or would it just not work right? thanks.
Alright cool, do you think it would look way off or not lined up at all though? thanks very much.
Alright, yeah I already read through all that earlier, I thought 11" difference was big enough to probably just ask and make sure though, well thank you very much for your help, I'll try it out. :)
