Eyefinity With Triple Screens Help
anikan1297
I am currently trying to run triple monitors through AMD's Eyefinity. The monitors are LED Samsung S24D590L(Listed as S24D590PL on their webstie). When trying to create a Eyefinity display group we go through all stages and then encounter an error on the alignment part. After choosing the center alignment option, all three monitors go dark and never come back on. Unless I unplug one of the three monitors, not just a specific one. Then usually ends up a BlueScreen.
OS: Windows 7 Ultimate
Video Cards: 2 Radeon R7 260X(CrossfireX)
Processor: Intel Core 2 Quad Q8300 at 2.5Ghz
RAM: 8 GB
Power Supply: 680 Watt
Connections going to monitor are [DisplayPort to HDMI] [HDMI to HDMI] [DVI to HDMI]. All monitors are hooked up in the back through HDMI.
________
| 3 | 1 | 2 |
Monitor Configuration
All help will be very much apprecatied!
you sir is in need of an active display port adapter. 😀
or try to hook up the last monitor on the 2nd 260x and see if it works. if not you really need an active display port adapter.
