I know that there are many posts regarding Eyefinity here @ TH. I have read most of them and haven't found a definitive answer that helps me get it working. Here is my current configuration:
Dedicated Graphics:
MSI Radeon R9 270 (2GB) (2 CG's assumed)
Motherboard/CPU
ASUS Z97M-PLUS
Intel Core i5-4570 (IG Disabled)
Displays:
1x RCA 24" LED24A45RQ (Link)
2x RCA 24" LED 24G45RQ (Link)
All TV's are same family, one 2010 model, two 2014 models. All set to 1920x1080. They only allow HDMI and VGA connections.
Extending or Duping a screen in CCC reports a disable is required. Windows simply wont, claiming it is unable to save the configuration.
Cable Layout:
DVI->HDMI (Passive) (Link)
HDMI->HDMI (Passive)
DP->HDMI (Active) (Link)
Windows reports them all as "HDMI" connections. CCC shows HDMI/HDMI/DVI. Would this be an issue as no more than TWO concurrent connection types are allowed in an Eyefinity setup. Can I force change one to a different type at all?
With the above setup, I am still unable to enable the third display in CCC or Windows. It shows up, but remains disabled. CCC reports one display must be disabled, and windows says it is unable to save the configuration. Leading me to believe I was either duped and it is not an Active DP adapter when it says that it was. Or that my cable configuration is causing a conflict.
Dedicated Graphics:
Motherboard/CPU
ASUS Z97M-PLUS
Displays:
Cable Layout:
