Question Ez debuf LED
May 20, 2019
9
System build
Psu: Thermaltake 600w
CPU: Ryzen 3 1300
GPU: HD 7870
RAM: Corsair vengence LPX 3000mhs 16gb
Mobo: Msi b350 tamahawk
The red debug light comes on, as well as all the fans, GPU, LEDs, everything. But it doesn't not post, and it does not beep. I have tried countless things, putting in all the basics only like psu, and CPU, and HDD and, just one ram stick in all slots, I AMD lost for words.
May 20, 2019
9
I feel like it's also worth mentioning the GPU works with other systems I've tried it on just now. And also, when I attempt to hold down the power switch it does not shut off
May 20, 2019
9
DId you plug the cpu power supply cable into the 8 pin port on the motherboard? There's the 24 pin and the 8 pin.
Yep, both are in as well as the GPU cables. I was reading around and heard ryzen takes a while to boot the first time. I'm going to set up the fans and run it for like 5 or 10 mins and see what happens
