Question EZ Debug led is shining white
Jan 27, 2021
4
So, i just bought a new PC.
It has a specification as follow:
Cpu - AMD Ryzen 5 3600XT
Motherboard - MSI B450M PRO-VDH MAX
Gpu - GTX 1660S
i have update my bios to the latest 7A38vBB1(beta) version and besides, there shouldn’t be a problem for my motherboard to run the CPU.
And my monitor recieved “no signal.”
However, it the ez debug led was shining beside the cpu for 5 seconds before it was gone. Any solution?
4
Gpu - GTX 1660S
i have update my bios to the latest 1.0.0 version and besides, there shouldn’t be a problem for my motherboard to run the CPU.
However, it the ez debug led was shining beside the cpu. Any solution?
I have tried to reset the CMOS battery twice and re-install the CPU but no result.
If the LED light corresponding to the CPU lights up and stays lit then return the system to place of purchase otherwise you will risk your Warranty. The trouble shoot indicates the CPU is not recognized or failure.
If this happened after Bios update then try reverting back to previous Bios.
Jan 27, 2021
4
No, it stays for 5 seconds and then the light turned off.
