AMD Ryzen 5 2600x
MSI Bazooka A320m
Ballistix 16gb 2666mhz (2x8gb)
GTX 1050 ti
Hey all, I had a Ryzen 3 1200 so I decided to upgrade to the Ryzen 5 2600x. It worked normally before changing the CPU.
When I turn the PC on, the stock CPU cooler fan spins, the GPU fan spins and the PC case fans also spin.
In the EZ Debug part, the CPU LED turns on first and STAYS on , then a few seconds later, the DRAM LED turns on and STAYS on. Both LEDs are on and there is no display output. The PC DOES NOT turn off until I turn it off manually.
I've tested the RAM by removing one stick and leaving the other in, then swapping them, however still no post.
MSI Bazooka A320m
GTX 1050 ti
