EZ Debug (white) LED CPU blinks
Runurse
9
Yesterday, I received my new PC so I set it up with no problem following some tutorials on the Internet and when that was the moment to turn it on
Suspense, nothing appeared on display..
I've tried to solve the problem but it wasn't successful
Configuration :
- MSI B250M PRO VDH
- Intel Pentium G4560
- G.Skill Aegis DDR4 8go 2400 Mhz
- Crucial MX300 M.2 2280 275go
- MSI Radeon RX 480 Gaming X 8go
- LEPA B550 MB Modular 550W
So i've tried to launch it only with the mobo, proc, ram, ssd and power out of the box.
The CPU Fan work in fits and starts and the EZ Debug (white) LED CPU blinks but nothing on screen..
I'm a little bit confused and short of idea to solve this
PS : Week-end mean no after sales services ....
PS2 : I've already tried to clear the cmos but nothing change
Hello everyone,
After differents tests and multiples calls with the ASS we found the cause of the problem !
That was the alimentation that wasn't working well, because no power means cpu stucks that's why fans were low turns working.
So, I've just change my alimentation and everything and YES, mobo turns perfectly !
Thank you for your help !
When i plug speakers on motherboard and turn it on ( motherboard ). It sounds like medium tempo (2 per seconds)
I think that my motherboard has an available port for it but i haven't a wire for it
http://imgur.com/a/vl1tL
Is it the JFP2 port ? If yes it's available
When I start the board with no RAM's installed it make the same sounds as last time and with RAM's installed, same beeps.
No, it doesn't.. Only White EZ Debug LED
I have already done what you're saying but it stay like ever : EZ DEBUG WHITE LED CPU ON so No signal on display
I think that Monday I will call the ASS of MSI
According to Msi's Motherboard, problem comes from CPU but physically it looks good, no bent pins, his radiator is ok if we do not focus on the fact that fan work in fits and starts following the tempo beeps and alimentation is working well and correctly plugged
Same Problem here, did you solve it? CPU oder mobo not wokring?
Hello everyone,
So you basically just changed your power supply and it worked? Because i have the same build except for the power supply and ram.
Reactions: ZevlagGerald
