So I just bought all my needed part off amazon and put it all together, I made sure everything was compatible, after I put it all together I turned it on and the CPU cooler fan spun up, case fans, GPU fan, everything seemed to work but my EZ debug lights keep going from a hard 2-3 seconds on DRAM then switch to CPU real fast, I've swapped places for the RAM several times and it doesn't change the outcome, the weird thing is when I completely removed the RAM the speaker started beeping but when the lights are flashing it doesn't.
My monitor also doesn't pick up input from my PC, I'm hoping that's just because the RAM might not be working.
(I should also mention that when I received my RAM in the mail it's box was partially open and scuffed up so maybe that could be it?)
