Question Facing problem when want to stress test after oc 3200g in Asrock B450M HDV 4.0.
Jul 22, 2020
I can't overclock properly in my pc when I tried to oc using Ryzen Master it just restarts. Then I tried this from BIOS but my pc can't open and didn't show in the display. It just automatically restarts and it sounds like beep beep. Then I have to reset the BIOS using CMOS battery. I update my BIOS from 3.30 to 3.90 but still faces the same problem.
I tried 3.7 GHz, 3.8, 4.0ghz, and face the same problem. Then tried the igpu 200 to 500 and face the same problem. When I tried to oc the cpu and igpu I turned on the XMP profile and I set the core voltage 1.35v for 4ghz,1.325v for 3.9ghz, 1.3v for 3.8ghz&3.7ghz. For apu gfx volt was 1.2 for 1550mhz and 1500mhz. My room is an air conditioner room and the idle temp is 29-35 degrees Celcius when playing any game then the temp is around 42-50 degrees Celcius.
My pc specs Ryzen 3200g mobo Asrock b450m HDV 4.0 and ram 2X8=16 GB corsair vengeance LPX c16 3200mhz. Apacher 240gb SSD and Seagate Barracuda 2016 1TB. PSU is corsair cv450 80 plus bronze certified.
